Thread: Vacuum routing
    Jdmoore20's Avatar
    Jdmoore20 is offline Junior Member
    Dec 2019
    1
    Vacuum routing
    I am in the end stages of doing a frame off restoration of my 1979 CJ5 with a 304. The vacuum lines are killing me. When I got the jeep 14 months ago, most vacuum lines were either cut or capped or hooked up haphazardly. There is an aftermarket air filter unit (edelbrock), and no air pump, such as all the diagrams in the service manuals show. So, rerouting some is a must, but to what I have no idea. Any help would be much appreciated. I would like to see some pictures of 304's that are running great and are similar to mine. Or if anyone has the 304 and lives in the Lawton area, let's meet and i cab see jokes yours is set up. I have a timing issue also but that can be a different discussion after I know my vacuum lines are in good order. Thanks bunches!
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,038
    Re: Vacuum routing
    Regards,
    JPNinPA
    Sent using TapTalk
  1. Brake Line Routing
    By dennisonwj in forum CJ YJ TJ and JK
    Last Post: 08-26-2014, 12:27 PM
  2. Engine harness routing
    By blaylock6502 in forum CJ YJ TJ and JK
    Last Post: 03-06-2013, 03:31 AM
  3. belt routing
    By mtman in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-25-2011, 01:26 PM
  4. air intake routing
    By currupt4130 in forum General Chat
    Last Post: 04-17-2004, 10:02 AM
  5. pre '95.5 2.5L serpentine belt routing
    By Bounty__Hunter in forum CJ YJ TJ and JK
    Last Post: 11-25-2003, 11:14 AM
Tags for this Thread
