Help with front diff and power steering
ottawajeep
When I put the 4X4 on the front end "holds back or hops" going in a straight line (forward and reverse) riped up my grass and it also did it on asphalt
The diff is full of oil-vacume lines seem to be ok
ANY IDEAS?
I have a power steering box and pump can I just swich the power steering box or do I ahve to change anything else?
email me with any ideas please @
lpaul@seacorcanada.com[addsig]
1076381
Sounds like something is binding in the transfer case, near the front output. Is the transfer case the NP207?[addsig]
1076543
No viscous coupling on an '87 YJ, I thought those were only found in full-time 4wd like the Quadratrac?[addsig]
1076894
This may help(or not)
When I had the jeep on stands(and no front shaft on) the tcase was spinning ok when it was put in 4X4
hope someone can help[addsig]
1076918
If it were something binding in the front axle, it would do it in both 2wd and 4wd.
Which front tire locks and drags in 4wd?
The transfer case may be shot to the point the front output spins fine with no load (no driveshaft) but binds when a torque load is applied.[addsig]
