help for the beginner.
jawjaboy
im thinkin about adding shackle lifts on my yj. i would like to add a suspension lift later.is this somthing i should do at the same time? will i need new shocks for the shackle lift.probably showin my ignorance here but. how are they installed??[addsig]
1040857
thanx terry, you are the man. im pretty sure the shackles that are on it are stock. they are 4" from bolt center to center. does this sound right?? how long will the ones for 2" of lift be? all i need are 2 pair ? for the very front of the front springs and the rear of the rear springs? what happens to the other end of the springs? they stay put??
Thanx for all your help and patience
Jawjaboy [addsig]
