Inspector-Gadget
Hardtop Paint
A magical cure???
My CJ had the characteristic valve cover oil leak and a slight oil drip at the crank rear seal. Neither leak was serious, so I have just ignored both leaks.
A few weeks ago, I replaced a defective PCV valve and all associated hosing on the Bubbacon's I-6. Having wwwaaayyy too much free time on my hands, I also degreased and cleaned the motor.
Lo and behold, both oil leaks have since stopped.
My theory is that the defective PCV valve put the engine under excessive internal pressure. That excessive pressure vented off through the valve cover gasket and crank rear seal, forcing some oil by the valve cover gasket and rear seal in the process.
That is my theory, but I would like to hear your theories for this seemingly magical cure of the Bubbacon's oil leaks.
I have done nothing else to the engine related to oil leaks: no oil changes, no mechanic-in-a-can sealing oil additives -- nada.
Any theories?
Gadget
A magical cure???
Any theories?
Gadget
