Tombredone
I have a '82 CJ 5, 6 cycl with a weber carb. Even before I put the new carb on, I keep blowing the seal under the valve cover. Two shops have resealed it, with and without gaskets. The most recent type at the shop to do this, it held for a day then started leaking on the drivers side. As I was checking out the leaking, I noticed 4 small hair line cracks in the valve cover itself, about midway up, and they were space across the length of the cover. This is a brand new valve cover. I have replace the pvc about a month ago. What is happening and how do I fix it,, To much compression? Pull the pvc and put a filter cap? HHHeeelllpppp
Thanks
thomas
Thanks
thomas
