joejeepny
I have a '93 wrangler and I have a problem with the steering. When you turn the wheel from left to right the tie rods twist up and down. This twisting action causes play in the wheel and a squireling effect to my driving. Its very annoying becuase the wheels do not go straight. It kinda rocks back and forth. Has anyone noticed this on a YJ. It doesnt happen on the CJ because the drag link is attach to the knuckle and not to the other tie rod. Is this a flaw with the YJ or is my tie rod bent, it doesnt look bent and if this is the case its always going to be bent from wheeling in the rocks? I would hate to replace it and have the same thing happen. Can someone with a YJ have someone turn thier wheel back and forth and then take a look if thier tie rod rocks also. You can see the streering stabilizer rock up and down. How do you stop this?
