images....
_(OIIIIO)_Jeeper
RE: Re: RE: Where has been Sully ?
Started this as so not to hi-jack Sullys Vacation Post...
the image in my sig quit showing up.....even though I have made NO changes to itand the pic is still @ tinnypic.com
this is the direct web address: http://tinypic.com/1j8tx
_(OIIIIO)_Jeeper wrote:
Why is my sig pic not showing up now...haven't changed anything, and the pic is still there @ tinypic........
check it out....
Try adding the / at the end of the address. (ex. instead of http://tinypic.com/1j8tx , use http://tinypic.com/1j8tx/, which is more correct. )
EDIT: never mind what I said above. Your problem appears to be that your image file has no designated file extension. That is, it IS a JPEG image file, but the filename appears to lack the *.jpg at the ending. Rename the file from 1j8tx to 1j8tx.jpg and upload it again. Then put http://tinypic.com/1j8tx.jpg in your sig line. Files which have no labeled extension (ex. *.xxx) are accessed as a generic file and only load/work in some instances (if you're lucky).
-Nick
It had .jpg on it when I hosted it at tintpic about3-4 months ago...the tinypic address is what they gave me
***sigh***
Hi,
Also, What is the host for this image? Is it one of those free sites which you have an account on?
-Nick :!:
Yes tinypic.com...free hosting. I don't understand why I can go directly to the pic on their site.......
but I am a computer MO-Ron! :shock:
Hi,
Check your Personal Messages. If you didn't get mine, check to make sure your inbox is not full. :mrgreen:
-Nick :!:
