02-27-2009, 01:13 AM #1
96 grand cherokee cranks but won't start
I have a 96 grand cherokee that has issues. I can drive it 4 a few months with no problem and then one day I will go to start it and it won't turn over. It cranks but won't start. I could drive it all day, stop at a store on the way home, and it won't start when i get back in to go home. However, it is very spurratic. Also, there are times that while I am driving, the rpms will go to zero and I will have no power to the car. Then about 10 seconds later it will catch and everything will be fine. Other times it won't catch and the car will stall. it might start up right away or it might take 10 mins or a few hours. Can anyone tell me where to start?
02-27-2009, 01:21 AM #2
Re: 96 grand cherokee cranks but won't start
It sounds like a CKP,(Crankshaft position sensor) with a bad connection or failing. Check for spark when the no start condition occurs. if there's spark then i would check the ignition circuits on the Run position.
06-13-2022, 11:28 PM #3
06-14-2022, 05:16 AM #4
Air fuel and spark run the engine.
As noted check CKP as it is known to fail like described and directly control spark along with cam sensor.
Next would be fuel pressure from start to 3300 rpm
Never look down on anyone unless you are helping them up - Jesse Jackson"Never look down on anybody unless you're helping him up" - Jesse Jackson
06-21-2022, 08:34 AM #5
the zj model grand cherokee are known for having issues with the mother board in the ecu. have someone push the plug into the ecu when you are turning the key and see if it starts better. after a while though, even doing that won't help. i always ended up buying a replacement ecu on ebay from someone who fixes those bad solder joints on the mother boards.
03 rhd tj
Jeep cranks but does not start. No check engine light.
By Nucks in forum Cherokee, Commander, Wagoneer and LibertyReplies: 14Last Post: 10-06-2014, 08:56 PM -
03 Jeep Grand Cherokee won't start at times
By sodbuster2x in forum Cherokee, Commander, Wagoneer and LibertyReplies: 2Last Post: 01-04-2009, 04:12 PM -
Cherokee cranks over no start ,no gauges
By scottz in forum Cherokee, Commander, Wagoneer and LibertyReplies: 2Last Post: 10-11-2007, 12:19 AM -
2001 Grand Cherokee start up problems, etc
By roooookie in forum General ChatReplies: 1Last Post: 06-10-2005, 06:08 PM -
93 Grand Cherokee Limited - Stalling and now won't start
By mrworkrate in forum Cherokee, Commander, Wagoneer and LibertyReplies: 1Last Post: 07-20-2003, 08:00 PM
