What's this wire.
southtj
Active member
So I was poking around the Jeep and removed the glovebox and see this blue/maroon wire just hanging there. It has a spade type connector on the end and I don't know if I should stick it somewhere or just leave it alone. What do you think.
Does your jeep have all options that were available for it? If not, it could just be a wire for a factory option that your jeep never had installed....like air conditioning.
If you have the FSM for the 03-04 TJ's it will tell you what it is, if you don't have the FSM PM me and I will see to it that you can find it.
~Curt
rear mainshaft bushing on np231
Figured it out. It was for the rear wiper on the hard top. It plugged in on the top row 2nd from the right in that picture. I just put the top on last week and hadn't even thought to check to see if it worked. I know that it worked last winter so how that came unpluged, I'll never know. Thanks for the help guys.
