Thread: defrost
    Will's Avatar
    Will is offline Member
    Jan 2012
    Tennessee
    90
    defrost
    the wife has an '04 unlimited,soft top,complains about the rear window not defrosting.what do you guys do,other than let it run?
    Pro Patria-Ne desit Virtus
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,031
    Re: defrost
    Other than letting it run. I will take a pitcher of warm water and splash it on the front sides and rear windows. It will often freeze but usually ends up defrosting quicker. If you wait for it to start to get warm inside it's more likely not to freeze.
    I do not scrape or wipe any windows.
    Jester32's Avatar
    Jester32 is offline Senior Member
    Nov 2010
    Alberta. Canada
    1,546
    I use the anti fog for scuba diving. Works great. Apply once every couple of weeks
    Will's Avatar
    Jan 2012
    Tennessee
    90
    Re: defrost
    what is anti fog? I have a good idea,but don't know were to purchase.remember Tennessee is land locked.
    superj's Avatar
    Feb 2010
    texas
    5,754
    Re: defrost
    isn;t it bad to put warm water on frozen windows?
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,031
    Re: defrost
    Quote Originally Posted by superj View Post
    Why? And are you referring to the glass or plastic.
  7. #7
    superj's Avatar
    Feb 2010
    texas
    5,754
    Re: defrost
    glass.
    i thought when you put warm or hot water on frozen glass the sudden temp change caused an uneven rate of expansion and caused the glass to crack sometimes?
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,031
    Re: defrost
    If you had a chip or crack you might end up with a bigger crack. But it will not start one. The automotive glass is resilient and could put up with large temp swings.
  1. Defrost / Heat
    By JTR0569 in forum CJ YJ TJ and JK
    Last Post: 09-18-2009, 12:14 PM
  2. 99 XJ No Air to Windshield on Defrost
    By Nick Mud in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-14-2009, 11:33 AM
  3. stripped? Defrost/AC knob?
    By Abutterfly in forum General Chat
    Last Post: 11-26-2006, 10:58 AM
  4. hartop rear defrost question
    By jaketime81 in forum CJ YJ TJ and JK
    Last Post: 04-22-2004, 12:59 AM
  5. tj defrost trouble
    Last Post: 08-23-2003, 01:35 PM
