Thread: dome light
    dome light
    I'm pretty sure this may sound really stupid,but here goes.Looking at my wrangler yesterday,thing of warm weather and taking off the top,and doors.The dome lights will stay on without the switch being closed by the doors.What??
    Pro Patria-Ne desit Virtus
  2. Re: dome light
    Disconnect switch,take out light bulb,install toggle switch,leave the doors on,take to dealership and let them figure it out.
    Oct 2011
    Millersburg, Oh
    449
    On mine all I did was simply reomve the fuse. Mine was a '97 TJ tho, what year is yours?
    Just
    Empty
    Every
    Pocket
    Re: dome light
    i just unhook the wire at the switch by the door
    Re: dome light
    2004
  6. In my TJ I just take the bulb out in the summer and put it back in when I need I also put the bulb back in for the winter
  7. #7
    May 2004
    Nags Head, NC
    3,909
    Re: dome light
    On my '03 I just removed the fuse also. Easiest solution.
    Just Enjoy Every Possibility!
  8. #8
    Re: dome light
    What's a dome light? :confused:
    93 Sahara. has some stuff... Want more stuff
    South Florida Jeep Club Treasurer
    http://www.sfjcforum.com
    http://www.stolenvalor.com
    http://www.standown.org
    http://www.woundedwarriorproject.org
    "Whether you like it or not, you better learn to love it! 'Cause it's the best thing going today! Whooooo!" - Ric Flair
  9. #9
    Re: dome light
    The dome light switch is a very very easy install. I use it all the time on mine.
  10. It's mounted in your sound bar just a light that turns on and off when you open and close your door
  11. Re: dome light
    I just up plugged that door switch and put a toggle in the dash. very simple, all you need is a wire that is grounded to go through the switch then to the light.
  12. #12
    Pull the fuse, or install the switch. I've also seen "clips" in the catalogs that hold the door pin switch in. Don't know how well they work though.
  13. #13
    Re: dome light
    Can't find the fuse.Not labeled on the box,no reference in manual.2004 Unlimited,red with black top.( I know that really don't matter,just had to).
  14. #14
    Feb 2012
    Trinity, Florida, United States
    480
    Re: dome light
    Dome light???? You don't need no stinkin' dome light.... It is a Jeep isn't it or we are talkin' BMers here..... Just kidding. I haven't had doors on mine for about 8 years. I just disconnected the wires by the doors. Little tape around the connectors and have been tucked away under the dash for 8 years. Good night my little dome light....LOL
    MOLON LABE
  15. #15
    Re: dome light
    i now have two dome lights. one in the back that is built into the hard top and one in the speaker bar i just installed. its going to be like day time next time the hard top is on and we get in at night, ha ha ha
  16. #16
    Quote Originally Posted by Will
    On my 06 unlimited, the fuse is in the lower right hand corner of the fuse box behind the glovebox.
  17. #17
    Re: dome light
    That would be #4,unplugged it,light stayed on.
  18. #18
    Nov 2010
    N. of Spokane summers, Las Vegas winters
    333
    Re: dome light
    don't even need the tape if the dome light was installed correctly, you only switching ground to the light bulb. so that wire is just a ground (switched) connection.. of course the plug for it has to be in good shape or it will turn your light on everytime it bounces to ground..
  19. #19
    The dome light is on a delay timer from the key, it should only stay on about 5 or 10 seconds after pulling the key out (with fuse removed) then go out. That's how my 06 is anyway. My fuse listings are on a sticker on the back of the glove box.
  1. 93 XJ dome light on
    By CoopDawg in forum All other Jeep models
    Last Post: 09-27-2011, 03:29 PM
  2. Dome light Question
    By 94Wrangler4.0 in forum Wrangler and CJ
    Last Post: 08-11-2010, 06:41 PM
  3. Dome light
    By Wanker in forum Wrangler and CJ
    Last Post: 11-04-2007, 08:30 PM
  4. Soundbar Dome Light
    By Robert_Strausberg in forum General Chat
    Last Post: 12-21-2003, 05:17 PM
  5. Dome light issues
    By bmsgolf in forum Wrangler and CJ
    Last Post: 11-13-2003, 11:22 PM
