Ected SUCKS
nswsparky
Last year I installed an Ected in both ends of my XJ. One in the front of my Jeep in the Wagoneer Dana 44 and one in the back in my 8.8. I have had nothing but problems with them. First the one in the front totally quit working even as a limited slip, it had less than 100 miles on it. I just sent that one in and got an ARB for the front. This last week I had drove my XJ out to moab and was doing Moab Rim; got past all the hard parts and was climbing a ledge towards the top, and bang. The Ected stripped out the splines on my passenger side axle shaft. I have the super 88 kit with Chromoly shafts so it does not have stock shafts. Once I got the shafts out I noticed that the side gear only engages about 1/2 and inch of splines of the shaft. I have seen some forums that say it is 2 piece and it engages more of it when it is engaged but I don't see that as being the case there is only 1/2 an inch of splines machined in the side gear, and I had it engaged when I tried the ledge. Long story short I had to overnight a shaft, ended up costing me a little under $1000 to get it back moving, and I was afraid to run it on the trails anymore because I did not want to strip out another one. So if anyone is looking into a Ected DON'T GET IT. They are not a real locker just a limited slip and a tighter limited slip with them engaged. But I think it would work fine on a street mostly vehicle or a race track car but on a wheeler not so much. So if anyone wants to roll the dice I will be selling this thing for $150 less than 1000 miles on it still works like new.
Here is a picture of the shaft, only engages like half an inch of the splines the marks farther down the splines are from the stock limited slip diff I had a year prior that engages like and inch and a half of splines.
This pictures shows that the axle fully inserted it engages all the splines it can, the shaft is not too short. this is the locker disengaged but engaged does not change the spline engagement.
Hey sparky, did you ever hear back about the front? Didn't know your were a member on here too.
People around here keep telling me to get an Auburn for my front - they seem to be pretty popular around here. I'm glad you posted this, I was thinking about getting one for my Dana 30
after watching them at r/c i was not that impressed, and this just makes it more so. i'll stick with arb's
