    Rsnyder22's Avatar
    Rsnyder22 is offline Junior Member
    Aug 2017
    4
    99 grand cheeroke extreme high idle 5k rpm
    Needing help got a 99 grand original motor quit after #4 piston cracked in half bought a used 4.0l motor 2003 jeep grand and installed it on start up eng. Revs up to 5k rpm and stays new timing chain trottle body sensors new cam sensor new crankshaft sensor. New ecm comupter No noticable vaccuum leak or air intake this gots me stumped on whats next to try.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,675
    Re: 99 grand cheeroke extreme high idle 5k rpm
    A vacuum leak is most likely. At the cylinder or the throttle bottle even a crack away from the engine. Like the vac resivoir under the battery. Second a bad or dirty IAC on the TB.
    Is there any sputtering or popping? If so it could be at a cylinder like the intake not married or bent or the gasket leaking from exhaust to intake. Even the or ing gaskets on the injectors.
    Regards,
    JPNinPA
    Sent using TapTalk
    k-2's Avatar
    k-2
    k-2 is offline Senior Member
    Apr 2017
    261
    To add to colleagues suggestions
    Check for codes.
    Confirm throttle is closed
    Rsnyder22's Avatar
    Aug 2017
    4
    2 New sensors on throttle body eng dies out with tb closed
    k-2's Avatar
    k-2
    Apr 2017
    261
    OK this is a replacement engine - in a 1999 GC,
    WHat ECM is installed the 99 or a 03?
    What codes are showing?
    What sensors and why?
    Wil eng start with TB closed?
    As mentioned knee jerk would be a vacuum leak - throttle stuck open..
    NOW you mention - Having TB open this suggest over fueling - check inj wiring - easy test with noid light or test light KOEO. Also heck fuel pressure regulator for fuel in vacuum line.
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,675
    Quote Originally Posted by Rsnyder22 View Post
    I take it you mean the TPS and IAC.
    I think the TB is closed on start. The IAC controls the airflow at idle.
    If you stall at idle with the TB closed your IAC is not connected properly, dirty or stuck.
    JPNinPA
    Using Jeepz.com app
  7. #7
    k-2's Avatar
    k-2
    Apr 2017
    261
    The TB is closed at start, opening a TB gives the engine AIR suggesting it is overfueling,
    Checking codes would ID a IAC wiring issue....and many other systems.
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,675
    Pull and inspect your plugs. Post pics of the plug tips before you clean or wipe....
    Regards,
    JPNinPA
    Sent using TapTalk
  9. #9
    Jeeprancher's Avatar
    Jeeprancher is offline Member
    Feb 2011
    Northern Arizona
    68
    I had that happen after spraying down the engine for its annual cleaning . Moisture in a plug connection . Took the ones around the throttle body apart , sprayed them with contact cleaner , let them dry , plugged them all back up . Problem solved .
    Also was already mentioned , the IAC is maybe stuck . They carbon up . Spray cleaner in the port . Most time you don't even need to take the untit out to clean it . There's just enough build up in there to make it stick . It might need more but I'd try that first .
    ɹǝʌo ǝɯ ןןoɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
  10. #10
    Rsnyder22's Avatar
    Aug 2017
    4
    2 new sensor on TB
  11. #11
    Rsnyder22's Avatar
    Aug 2017
    4
    JPNinPA
    Using Jeepz.com app
    No stall
  12. #12
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,675
    Did you spray around the intake, TB, injectors, plugs and vac lines with carb cleaner or WD40? If you spray with the engine running and the idle changes you just hit a leak.
    Regards,
    JPNinPA
    Sent using TapTalk
  1. High Idle
    By southtj in forum CJ YJ TJ and JK
    Last Post: 07-09-2011, 01:10 PM
  2. High Idle??
    By captjanes in forum CJ YJ TJ and JK
    Last Post: 06-04-2011, 04:22 PM
  3. 98' TJ high idle
    By jlynn33 in forum CJ YJ TJ and JK
    Last Post: 06-08-2009, 06:59 AM
  4. Idle too high.
    By uncleair in forum CJ YJ TJ and JK
    Last Post: 10-09-2007, 02:08 PM
  5. help with idle speed actuator ISA - idle way too high upon i
    By bucklahoo in forum CJ YJ TJ and JK
Tags for this Thread
