    Alex Gauldin's Avatar
    Alex Gauldin is offline Junior Member
    Jan 2019
    3
    subwoofer removal
    hey guys, i知 new here so i hope i知 doing this right. lol. i am trying to remove the factory subwoofer enclosure in my 2007 rubicon and i知 not sure what tools i need to use. i googled it and everything i found the guys had different kind of bolts so i知 confused. my bolts are pretty large and are 6-sided on the top like most bolts, but on top of that it has a large metal circle and i have no idea what tool i need to remove it. any ideas?
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,249
    subwoofer removal
    Not sure. What pic do they look like 1, 2, 3, or 4?
    1
    2
    3
    4
    Regards,
    JPNinPA
    Sent using TapTalk
    Jan 2019
    3
    Re: subwoofer removal
    they look like this
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,767
    The bold that that nut is screwed onto is a bit longer so they put that little dome on the nut to cover it.
    The best tool for this is a deep set socket:
    However a wrench should work fine as well (you'll use the closed end, not the open end.):
    These tools can be found at Walmart, car part sores, Home Depot, etc.
    Jan 2019
    3
    awesome. thank you for your help
  1. Power Brake Booster Removal / Left Hand Manual Pedal Assy removal help?!!!!
    By mike_beez in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 05-04-2015, 10:58 PM
  2. subwoofer
    By java4me in forum General Chat
    Last Post: 05-10-2014, 09:32 AM
  3. Subwoofer
    By SteelHeadz in forum Jeep Electronics and Audio
    Last Post: 01-23-2014, 10:03 PM
  4. subwoofer air needs
    By jerseyguy316 in forum Jeep Electronics and Audio
    Last Post: 12-11-2012, 10:45 PM
  5. Subwoofer Help
    By jacob123 in forum Jeep Electronics and Audio
    Last Post: 03-24-2010, 08:51 AM
