1. Poor man's lunchbox locker - partial Lincoln lock 3 spiders, grind 4th
    Having seen both "Lincoln lockers/spool" mods, and also the spider gear replacement kits that essentially create free play in a spool type configuration...
    I thought, what if you welded only 3 of the spider gears together (say top, bottom and one side) and then for the 4th side, ground off the sides of the teeth to create some free play then install with ground teeth aligned with other welded spiders.
    This way you would be able to take road corners without chirps but essentially have a poor man's lunchbox locker.
    Mechanically similar to this:
    Thoughts?
  2. Re: Poor man's lunchbox locker - partial Lincoln lock 3 spiders, grind 4th
    somehow it all looks dumb
  1. Cj7 trac-lok, lunchbox locker?
    By hguidry15 in forum Wrangler and CJ
    Last Post: 07-23-2019, 11:37 AM
  2. Which D30 Lunchbox Locker?
    By TerryMason in forum Wrangler and CJ
    Last Post: 03-01-2013, 04:32 PM
  3. Lincoln locker
    By LVRockCrawler in forum Wrangler and CJ
    Last Post: 10-23-2008, 01:20 PM
  4. Lunchbox locker - front or rear?
    By hi_c in forum Wrangler and CJ
    Last Post: 01-07-2004, 04:22 PM
  5. lincoln locker
    By Snitty in forum General Chat
    Last Post: 11-21-2003, 08:34 PM
Tags for this Thread
