1. Passenger back drain plug?
    Where is my passenger rear drain plug on my 97 Jeep Wrangler TJ?
    Are the coated areas shown drain plugs or there are no drain plugs in the rear of 97 TJ?
    Doing a DIY Jeep liner trying to get it right!
    Feb 2009
    Dayton Ohio Area
    5,951
    Re: Passenger back drain plug?
    Either of those can be popped out. They are metal and can be replaced with rubber grommets.
    Look at them from below to remove. It will be easier
  3. Re: Passenger back drain plug?
    Upon zooming in on the lower oblong boss, It appears to me that someone has poprivited a square piece over top of your drain plug and painted over it. . But looking at it for a second time, the grooves in the floor go to the other oblong boss which makes sense that that is where the drain hole is.
    Needs to go yonder.
  4. Re: Passenger back drain plug?
    Maybe the lower one is for snow, and the one with the grooves is for water, Hmmmm
    Needs to go yonder.
    Feb 2009
    Dayton Ohio Area
    5,951
    Wet and really wet
  6. Re: Passenger back drain plug?
    So you agree about the rain hole , and the snow hole ?
    Needs to go yonder.
  1. AC Drain Plug
    By mrnavy2 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-08-2012, 10:56 PM
  2. radiator drain plug
    By kreatos909 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-26-2010, 11:57 AM
  3. oil drain plug
    By djc321 in forum Wrangler and CJ
    Last Post: 05-02-2005, 09:48 AM
  4. Drain Plug for NP 231
    By jps4jeep in forum Items for Sale, Trade, or Give Away
    Last Post: 08-31-2004, 10:42 AM
  5. AMC20 drain plug question
    By 1981CJ5 in forum Wrangler and CJ
    Last Post: 12-26-2003, 09:56 PM
Tags for this Thread
