    Dec 1999
    Virginia Beach VA
    8,168
    In the market for a front Dana 30 diff cover
    Looks like I've dented, and possibly punctured my front diff cover, so I'm in the market for a Dana 30 diff cover. I'd say that my requirements are that it be under $150, and have a fill hole.
    I'm replacing stock, and don't know much about them, but from what I've read, cast iron is recommended.
    I'm not really a fan of having a huge log on my cover, however the poison spider one does look cool. What does everyone think of these:
    https://www.amazon.com/Poison-Spyder...132313&sr=8-20
    https://www.amazon.com/DV8-Offroad-D...132313&sr=8-10
    https://www.amazon.com/RuffStuff-Spe...3132313&sr=8-8
    The DV8 fill plug looks much higher than the others. I'm now sure if I actually filled up to that plug, if the fluid would leak down my axle tubes, and out or not.
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    Dec 1999
    Virginia Beach VA
    8,168
    Re: In the market for a front Dana 30 diff cover
    I just noticed that the DV8 claims it is for a JK with Dana 30 (I have a 2005 TJ). I didn't realize they were different. The other ones don't mention what year Jeeps they are for, only that they are for the Dana 30.
    Dec 1999
    Virginia Beach VA
    8,168
    Amazon claims this is the #1 best seller, and it's for JK & TJ front diffs
    https://www.amazon.com/Yukon-Gear-yh..._t4_B01M0DXAQI
    Feb 2009
    Dayton Ohio Area
    6,273
    Something to consider.
    Will the track bar hit it when articulating?
    Feb 2009
    Dayton Ohio Area
    6,273
    Cheaper mixed variety.
    2005 JEEP WRANGLER 4.0L L6 Differential Cover | RockAuto
    Dec 1999
    Virginia Beach VA
    8,168
    Thanks for the tip. I just bought the Spicer cover from RockAuto - I like to drain and fill holes, and it looks pretty good. It was a toss up between the Yukon and Spicer, as they both look pretty good.
    Just by eyeballing it, I think the Spicer may have a bit more clearance for the trackbar though.
    More Information for DANA 10023534
    https://www.amazon.com/Spicer-100235.../dp/B01MF6D03D
    What fluid do you recommend? I do have an Aussie locker in the front (lunchbox locker). In the past I've used Mobil 1 80w-90.
  7. #7
    Feb 2009
    Dayton Ohio Area
    6,273
    Conventional 80W90 unless you tow distances or live in HoT climates.
    Add trac loc if you have limited slip.
    D30 1.8 qts
    D45 2.0 qts
  8. #8
    Dec 1999
    Virginia Beach VA
    8,168
    I'm pretty happy with the results.
    Off with the old
    The new cover if beefy and has a plethora of drain / fill plugs
    The only fault I can find is that the drain plug hangs a little lower than I'd prefer. We'll see if that ends up being an issue.
  9. #9
    Feb 2009
    Dayton Ohio Area
    6,273
    Last pic looks like the track bar might rub @ full flex. I could be wrong. Check it in a controlled setting. Like on a lift. Better to find out now than on the trail.
    Drain plug??
    Hit it with some paint you clean out later. OR, Just drain like you did last time.
  10. Re: In the market for a front Dana 30 diff cover
    Update us if it would still have a dent knowing that it's already iron.
  11. #11
    Dec 1999
    Virginia Beach VA
    8,168
    I'm not really sure where the dent in the factory cover came from, or if the new cover would have handled it better.
    I think I didn't clean up enough before putting the new one on though - as I have a small leak / drip. I'll need to take the cover off again and clean up before putting it back on.
  1. Buying Used JK, 2015 Front Diff Cover Permatex Gasket
    By doogymon in forum Wrangler and CJ
    Last Post: 06-13-2017, 10:58 AM
  2. Dana 30 & Dana 44 Diff Covers at Motobilt
    By motobilt in forum 4x4 Vendors
    Last Post: 09-19-2016, 10:17 AM
  3. Diff cover gasket or RTV?
    By Collin the Hen in forum Wrangler and CJ
    Last Post: 10-12-2008, 10:18 PM
  4. Dana 35 diff.cover
    By BigDaddys88YJ in forum Wrangler and CJ
    Last Post: 03-13-2005, 09:15 PM
  5. the diff cover wont come off the dana 30!!
    By Tug-n-pull in forum Wrangler and CJ
Tags for this Thread
