GenRight Off-Road overhauls customer rigs!
GenRight Off Road
Not only does GenRight Off-Road manufacture quality aftermarket off-road products, we also overhauls customer rigs! This thread is where we will post up recent and future builds!
New York Customer - 2002 Jeep Wrangler TJ
Currie Enterprises - Rock Jock Super 60 axles
• Legend Extreme Suspension System (GRCFSKLE)
• Front Hoop Kit (FSM2004)
King Off-Road Racing Shocks - Dual Rate 2" Coilovers with Res and Clicker Adjuster 14" front & rear
• 3 Link Front Builders Kit (SUP3101)
• Rear 4 Link Builders Kit (SUP4101)
• Sway Bar Assembly (SWB1003)
• Rear Shock Mount Kit (RSM1001)
• EXT Crawler Gas Tank (GST2002)
• Stretch Rocker Guards with Side Bump Bars (RCG5003)
• Stretch Corner Guard Set (CNR2013)
• 1" Motor Mount Lift (DVL9200)
• New Style Universal Transmission Crossmember Kit (BKT1051 & BKT1050)
• 1" Body Lift Kit (BDL9200)
Advance Adapters Inc. Atlas II 2 Speed Transfer Case
• TJ Belly Up Skid Plate (SKP2500)
• Drag Link Correction Kit (STK2503)
• Tie Rod Kit, Chromoly (STK5750)
AGR Performance RockRam Engine (AGR355251K07TJ)
• Cooler Kit, 4-Pass Power Steering (STK1320)
• Steering Box Skid Plate (SBS2001)
• Bump Stop, Lower Link Bracket Kit (SUP1001 & SUP1002)
• 4" Air Bumps 2.0" Diameter (KAB2002)
• Full Weld In Rollcage (GRC2001)
• Dash V Bar Kit (GRC2054)
• Door Surround Adapter (GRC2010)
• Cage To Frame Tie In Kit (GRC5500)
• Rear "Swing Out" Tire Carrier (RTC3510)
• LED License Plate Frame (LED1640)
• Rear Crossmember Bumper Plate (RTC3520)
• Frame To Outer Rear Bumper Bracket Set (RBB1100)
• 6" Aluminum Tube Fenders (TFF2810)
• Stealth Marker Light Kit (LED1004)
• Inner Fender Well (TFF2SIF)
• Rear Tube Flares 6" (TFR1031)
• Boulder Stinger Front Bumper (FBB2100)
WARN 97600 9.5 Cti-S, Synthetic Line
• Fairlead with New Logo (FBB5001)
• Beadlock Wheels, 17 x 8.5, 5 on 5.5 with 4" Backspace (WHEELS)
The Goodyear Tire & Rubber Company 40" 13.5R17LT MT/R's with Kevlar
PRP Seats Enduro Seat Recliner (PRPENDREC)
• PRP Seats Safari Top for GenRight Rollcage (AGRCSTOP)
________________________________________
SpiderWebShade's TJ currently being overhauled!!
Going on the SpiderWebShade TJ includes the GenRight aluminum corner guards, aluminum tubular fender flares with LED marker lights, GenRight rock guards with Lite DOT LED tail lights, and much more!
