Rear Round LED Brake Lights Flush Mount??
scooter7728
I've seen it on a few jeeps on some forums I like that it removes the clunky box light. Anyone on here do it? Just wondering if they sell a kit or should I just go to a truck center and get two lights and rubber gaskets/holders. What did you use to cut the hole? any posted pics would be appreciated. thanks
I've installed them on a few rigs i built for our local crawlers here. It's cheaper to get them from a truck stop .just make sure it's a 12V unit. Buy a hole saw from Home depot to cut the hole. Remember to also change out your flasher unit to an electronic flasher for an L.E.D. application or you can install a load equalizer.
that electronic flasher will fit right into the jeeps socket? thanks again
