YJ Switch Panel
clydethepirate
Needed a place for my Off Road lights and on a YJ its obvious where they need to go.
1st toggle on left to lights mounded on windshield frame.
2nd toggle is to the fog lamps.
3rd toggle is for rear lamps.
Two Marine Grade Power Ports
And the switch in between the power ports is a monentary switch that turns on driving and fog lights together while you hold the switch down.
And the two smaller holes underneath the power port........... screw up!
Looks like you did a good job there. clean to. I chose a different route. I went with a switch box by Federal signal. (sw300) I was on the Fire dept a while ago and used it to control all my lights then. still do , but not the red ones. Ill post a pic in a bit. still in progress though.
