2000 jeep wrangler se cigarette lighter
kearashae
My cigarette lighter doesn't work and was wondering what I need to do to fix it. Is it a fuse thing or wiring? So annoying I need to get this fixed...
Are you using the cig lighter to try it? The coil end of cig lighters can fail. Did you try, say a cell charger cord to see if it works? Their should be a fuse. Check that the wires are connected on the cig receptacle.
fuse would be the first place I'd look. Fuse box is behind the glove box. Open it, slide the strap off, squeeze the sides and let it drop.
