Page 3 of 3 First 123
Thread: Switches
  1. #41
    Turbogus's Avatar
    Turbogus is offline Senior Member
    Nov 2005
    Albany~town, Oregon
    1,328
    Re: Switches
    Since they're incandescent they're not as bright as an LED would be and my view of that panel is slightly obscured by the shifter lever anyway. I found the circuit I tapped into that I mentioned earlier is a Key on circuit so there's no danger of leaving them on by mistake.
    Quick fixes are so named for how long they stay fixed.
    If you run out of gas, no matter which way you decide to push, the closest gas station will always be uphill and in the other direction. Corollary: The likelihood of running out increases when all of the nearby gas stations are closed.
    The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep.
    We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch).
  2. #42
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,328
    Re: Switches
    I found some metal parts under the dash but they don't seem to have continuity to the negative terminal of the battery. Switches-2012-03-06_211819_1.gif
  3. #43
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,328
    Re: Switches
    Wired with a ring terminal and an extra nut on the bottom of that strap holding the horizontal bar for ground, found a key on power source to the fuse panel and learned that save for four mounting screws across the bottom of the dash, the lower and upper dash is snap-fit. This surprised me, but then I haven't driven anything later than an '81 in recent years. The lights work fine now just wiating on parts to finalize the switch.
  4. #44
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,328
    Re: Switches
    Eventuallly I'm going to make my own battery cables for this truck 'BBB' as I did for 'BB'
  1. See my new switches panel
    By Yijun2015 in forum Jeep Electronics and Audio
    Last Post: 10-04-2015, 05:04 AM
  2. Replies: 0
    Last Post: 02-10-2011, 05:52 PM
  3. What are these switches?
    By GaryMB in forum CJ YJ TJ and JK
    Last Post: 02-25-2005, 09:38 PM
  4. Door switches?
    By wm69 in forum CJ YJ TJ and JK
    Last Post: 11-14-2003, 01:12 PM
  5. foglight switches
    By MudderChuck in forum Cherokee, Commander, Wagoneer and Liberty
