Page 1 of 3 123 Last
Thread: Switches
    Turbogus's Avatar
    Turbogus is offline Senior Member
    Nov 2005
    Albany~town, Oregon
    1,327
    Switches
    oops goofed
    Attached Thumbnails Attached Thumbnails Switches-wp_20161229_12_26_51_pro.jpg
    Quick fixes are so named for how long they stay fixed.
    If you run out of gas, no matter which way you decide to push, the closest gas station will always be uphill and in the other direction. Corollary: The likelihood of running out increases when all of the nearby gas stations are closed.
    The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep.
    We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch).
    greg92jeepxj's Avatar
    greg92jeepxj is offline Official Supporter
    Apr 2013
    Staten Island n.y.
    2,000
    Re: Switches
    Pardon me for saying , but the jumpers on the fog light switch are crossing each other which most definitely will cause an arc. Sorry about that �� .
    TLCJ5's Avatar
    TLCJ5 is offline Senior Member
    May 2010
    Livonia,Mi
    671
    Re: Switches
    nothing a 3inch blob of solder won't fix....
    Tom Landvogt
    1978 CJ5(my toy)
    1999 TJ Wrangler Sahara(daily driver)
    2001 Cherokee Sport(wifes Jeep/winter driver)
    2002 Dodge Dakota(to tow the CJ & Wrangler)
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,327
    Re: Switches
    Apparently these came off of a snowplow rig, and my guess is that those tabs are for lighting the switches when they're on.
    JPNinPA's Avatar
    JPNinPA is online now Senior Member
    Feb 2009
    Dayton Ohio Area
    4,561
    Re: Switches
    That switch is for lighting the switch and for reverse current circuits.
    JPNinPA
    Using Jeepz.com app
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,327
    Re: Switches
    I thought the wiring went like this;
    Mind you this is a Chevy switch...
  7. #7
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,327
    Re: Switches
    As part of this same project I'm trying out a pair of LED headlight bulbs, I ran one overnight last night with the standard composite bulb on the opposite side, photos don't do it justice but these certainly make a difference on the road.
    Attachment 22455Attachment 22456Attachment 22457
    Here's how the pattern is against a walll
    ...and at $35.00 I figured I couldn't go wrong.
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,561
    Switches
    You are correct.
    I was just stating the switch configuration is one used for reverse current circuits.
  9. #9
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,327
    Re: Switches
    One step forward and two steps back for my electrical knowledge
  10. #10
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,327
    Re: Switches
    Now I have to figure out if I can tap power from this interior fuse panel like the old GM ones in our CJ'sSwitches-wp_20170111_12_47_57_pro.jpg
    Attached Thumbnails Attached Thumbnails Switches-wp_20170111_11_03_17_pro.jpg
  11. #11
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,561
    Switches
    Be safe and use two relays. Don't have the power go thru the switch.
    JPNinPA
    Using Jeepz.com app
  12. #12
    superj's Avatar
    Feb 2010
    texas
    5,754
    Re: Switches
    just use the multimeter and find power. if you are going led, the switch is ok to have the power through it but I like to use a relay also. the leds draw so little power, they are amazing compared to older light bulbs.
  13. #13
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,327
    Re: Switches
    These are Bosch Xenon's that I had on 'Easy Bake' before she was totalled and they're amazingly bright for my purposes. I have this four pot relay panel left over from the CJ project last year.
    Name:  21706d1462743075-contour-fan-upgrade-need-step-step-please-kgrhqzhjcie-psh68b-bpvrchzlkq-60_12.jpg
    I'm just having to find a vacant circuit in the loom is that I can tap power for the switch from. I don't like the idea of 'piggy backing' electrical circuits unless absolutely nesessary and without comprimising anything else.
    Attached Thumbnails Attached Thumbnails Switches-17520d1375219759-contour-fan-upgrade-need-step-step-please-8468116857_1ca744c138_b.jpg
  14. #14
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,327
    Re: Switches
    It turns out that the photos above are what Chevy calls the "Conveniance Center" the actual fuse panel is on the left side of the dash with those dang mini fuses.
    Switches-wp_20170112_06_58_41_pro.jpgName:  07b6c06.gif
Size:  22.4 KBSwitches-wp_20170112_07_17_40_pro.jpg Number 23 is the one I'm hoping to tap into
    Attached Images Attached Images
  15. #15
    superj's Avatar
    Feb 2010
    texas
    5,754
    Re: Switches
    21 or 22, easy work
  16. #16
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,327
    Re: Switches
    There's NFP at those two circuits, but the Rear Window wiper (23) has power so I'll scab into it.
  17. #17
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,561
    Re: Switches
    Do you want the ability for lights to remain on with the key off. Or key off lights off?
    JPNinPA
    Using Jeepz.com app
  18. #18
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,561
    Re: Switches
    I'd use 22. What is the current draw expected?
    Each line of the fuse box adds up to ~70-75A
    With 22leaving 20A AVAILABLE
    JPNinPA
    Using Jeepz.com app
  19. #19
    Turbogus's Avatar
    Nov 2005
    Albany~town, Oregon
    1,327
    Re: Switches
    Those Bosch lights are so bright, I doubt I'd forget turning them off, not to mention the switch light. With this switch I'm only tripping the relay to the lights so the amperage is minimal. Circuits 21 and 22 do not have power to them.
  20. #20
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    4,561
    Switches
    Not that you would forget, but as an option. I wired mine so they could be on all the time if needed. There were times I'd want light a path or provide light without the vehicle running.
    You pulling the light power fused from the battery? That's fine then pick a fuse that does not go to any safety item. Number 7 have anything? There are fuse jumpers you could use to easily create another circuit without splicing. I'll edit a pic back in.
    Regards,
    JPNinPA
    Sent using TapTalk
  1. See my new switches panel
    By Yijun2015 in forum Jeep Electronics and Audio
    Last Post: 10-04-2015, 05:04 AM
  2. Replies: 0
    Last Post: 02-10-2011, 05:52 PM
  3. What are these switches?
    By GaryMB in forum CJ YJ TJ and JK
    Last Post: 02-25-2005, 09:38 PM
  4. Door switches?
    By wm69 in forum CJ YJ TJ and JK
    Last Post: 11-14-2003, 01:12 PM
  5. foglight switches
    By MudderChuck in forum Cherokee, Commander, Wagoneer and Liberty
