2003 jeep wrangler x v6 4.0L
HenryV
My question is that when my jeep is idle if i don't press the gas padel to make bring the rpm it will die out, it works fine all i have to do is keep the rpm's up.
Check the T.body first. Make sure it's clean from carbon build up and the IAC is not getting stuck.
SteelHeadz said:
BTW, that's an inline 6 cylinder.
X's 2. If its a v6 its a 2.5 or 3.7. 2.5's haven't been around since the 80's and I'm not sure if they put the 3.7 in wranglers
i think they started putting the 3.7 in the wranglers a couple years ago. i used to repo cars and some of them we picked up had a v6. This was only within the last 3 years if i remember correctly.
It's the 3.8 liter, not the 3.7 L that's found on the JK Wranglers. 2.8 turbo diesel is on the export only.
