GM HEI Distributor...
javcamac
Hi to all...
I recently change the old distributor motor-craft for a new GM HEI Distributor. Work great and also increase the power.
I notice that the motor slightly increase the Temperature while running. I think that's normal since the change of the new distributor with more power.
I appreciate any additional recommendation...
Thanks...
did your timing change? the only way temp increases if nothing has affected the cooling system is timing advanced or a lean running condition
