manual trans????
AX5 is considered light duty. AX15 is medium. Pretty sure the AX5 used a bell housing that was internal slave only, not that it can't be changed to external. Also I think the AX5 came in both 21 or 23 spline output shaft so you would have to swap it out if that doesn't match up for you. AX15 is 23 spline. What kind of transfer case do you have, what jeep is it going in?
My ax5 in my 99 Tj is external slave, I believe they made the change from internal to external slave around 90-91
Sent from my DROID 2 Global
Anyone know which transmission is better ax5 or ax15??. Converting from aw4. Mostly street use though.
One is not better than the other, they simply have different torque handling capabilities.
The AX5 will not bolt up to the 6cyl engine so if you have the 4.0L engine the Ax15 is the transmission for you.
