need help with brakes
dmassey
I bought the Truck recently and my brakes were not working. ive since replaced just about everything. everything is tightened and bleed and no lines are leaking. what can it be?!?! this is driving me crazy
No leaks, no air in the system but also no pressure?, i would have to guess that you have an internal leak on the primary and secondary piston in the master cylinder.
i just replaced it tho and bench bled it, could i have gotten a faulty one?
sorry i know its not really a "truck" im just used to referring to it as a truck..
as for specs its an 86 cherokee 2 door without abs and its got the gm V6
