2003 Saharah Jumps out of 4WL
germaneighter
2003 Automatic Saharah (daughter's vehicle) jumps out of 4WL many times before it will finally stay put. It has a 2.5" body lift. Someone told me there was an extension or adapter that I needed to install. Anyone have specific info on this?
thanks,
dg
Look here this may give you a idea on what to look for.
http://www.roughcountry.com/install/tjcombo.pdf
Look under (POST INSTALLATION INSTRUCTIONS)
Check the transfer case shifter to see if it will move to​
4L. If
not, the linkage will need adjusting. Place the shifter in
4L,
loosen adjustment bolt and push the linkage forward until it
stops. Now re-tighten adjustment bolt.
See Photo 1. Check to
be sure 4WD works properly.
Yes, I also installed a 2.5 inch lift in my 2004 Wrangler and had problems with my 4wd. the adjustment only takes 5 seconds to do and everything will be good to go!
