Jeep TJ engine 2.5 questions
spinellu006
I bought 97 TJ has a rod threw the block and its a 2.5 i want to keep the trans the same what w.5 parts can i use between gm and amc and what engines bolt up to the ax6 trans yes i know its a bad trans just need this running and driving asap
Sent from my SM-G930V using Tapatalk
Auto correct sorta messed that up
what are you trying to do, or wanting to do? simplest would be get another tj engine.
I just want to get it back on the road easy as possible till I have time to get into a swap
