Coolant leak
keecko21
I replaced my thermostat today and I noticed after I was done the coolant was leaking so I checked to see if everything was tightened and I noticed the leak was coming from a seal next to the oil pan but it's clean coolant....? Any thoughts of what it could be???
Sent from my SAMSUNG-SM-G935A using Jeepz.com mobile app
Welcome to Jeepz.com! Any chance you could upload a photo of the area where the leak is?
They are not crystal SO what year, model, engine Will we be lookin at?
You did use correct T'stat?
The leak the front or back of the engine?
Back could be a freeze plug.
Front could be the water pump or you may have cracked the thermo housing by tightening too much.
Regards,
JPNinPA
Sent using TapTalk
