Stalls for no reason, and then starts again after a couple minutes
Jeffs93
I have a 93 Wrangler with a 2.5 crate engine w/30,000 on it that runs great, the vehicle itself has around 210,000 on it.
I have replaced just about everything in the past 5 years that I've owned it......All of a sudden out of the blue it just stalls, for no particular reason. Sometimes it starts again right away and it's fine and sometimes it dont for a while but then it's fine later.. Any experiences and or ideas are welcome..
I cant go on a road trip... it's holding me hostage!
Help.
First check your battery connections and grounds at the body and engine.
A failing crank position sensor will act intermittent until it fails.
Only use OEM sensors.
Regards,
JPNinPA
Sent using TapTalk
