Rare Parts Ball Joints and Steering at Allen's Offroad
Allen's Offroad
Good day all.
Allen's Offroad is very grateful to be able to bring you Rare Parts products. Click an image to see them online. As always, just add to cart and go.
Dual Load Carrying Ball Joints
JK Steering Products
Great News for Jeep 4x4 Owners. Our revolutionary Dual Load Carrying Ball Joint System. Trail Tested, and made here in the USA.
RP12573 – Fits Jeep JK / WJ
RP12574 – Fits Jeep TJ / YJ / XJ / ZJ / LJ
UPPER BALL JOINT FEATURES:
Like nothing you’ve seen before. It uses our revolutionary adjustable load carrying cap to set load distribution
Unlike OE, this presses from bottom up, allowing it to carry part of the load
It carries an average of 20% of the load, reducing the load on the lower ball joint
Heavy duty – uses tapered roller bearings for load carrying, and PTFE lined epoxy bearings to compensate for misalignment, or bent inner C’s
All hardware is included
LOWER BALL JOINT FEATURES:
Eliminates OE nylon internals and uses a heavy duty, greaseable steel-on-steel design
Low profile housing clears RCV axles
32 MM powdered metal bearing replaces the undersized OE plastic bearing
All hardware is included.
Have a great day!
Allen
