Front Runner Outfitters Jeep Roof Racks
Allen's Offroad
Good day everyone!
Allen's Offroad is proud to offer the WF members and lurkers Front Runner Roof Racks. These are high quality racks and will stand the test of whatever you can throw at them. With a huge line of accessories and mounting systems, they will fit anyone's rack needs.
Check the JK/JKU racks out online by clicking the image below. I will have accessories loaded soon. Meanwhile, if there is something you want along with a rack, just put it in the order comments and I will get back to you with pricing.
With a huge inventory on the shelf, they can ship out in 1-3 business days, instead of other mfg's lead times of 12+ weeks. Less wind noise as well.
Have a great day!
Allen
This Slimline II rack kit contains all the components needed to mount the Slimline II cargo carrying rack to your Jeep including the Slimline II tray, the Jeep Extreme Mounting System, and a Wind Deflector.
This rugged, sophisticated, high performance, nearly indestructible rack system allows you to quickly remove the Freedom Panels and works with the hard top roof on or with no roof at all.
All Front Runner Rack Kits contain installation instructions as well as all the components needed to mount the Slimline II Tray to your vehicle.
These Foot Rails contain 1 opening to access a Front Runner under rack mount table (1 smaller prep table or 1 larger camp size table).
All Front Runner Racks are backed by a Limited Lifetime Warranty*
The JK Extreme mounting system bolts to the roll bar with middle and rear brackets. This unobtrusive, high performance, nearly indestructible mounting solution allows you to quickly remove the Freedom Panels and works with the hard top or with no roof at all. Freedom Panels can be quickly and easily removed with rack in place. The cargo weight is evenly distributed across the roll bars and body of the jeep, placing zero weight on the hard top itself.
Material used:
Black epoxy powder-coated T6 aluminium
3CR12 Stainless Steel
Approximate Installed Weight 46kg (90-100 lbs), depending on model.
The t-slots on the tops and bottoms of the rack tray slats and edge profiles accommodate standard 8mm bolts.
To determine the approximate height from your vehicle’s roof to the top of your Slimline II Roof Rack, add the height of the Slimline II Tray (50mm/ 2") to the height of the Foot, Grab-on Foot or Strap-On Foot.
If your Slimline II Roof Rack kit uses Legs, add the height of the Slimline II Tray (50mm/ 2") to the height of the Legs to determine the height of the rack from your vehicle’s rain gutters.
If your Slimline II Roof Rack kit uses Foot Rails, add the height of the Slimline II Tray (50mm/ 2") to the height of the Foot Rails to determine the height of the rack from the crown (highest point) of the vehicles roof.
