Hello Folks
I'm new to this forum. Have read a few threads and it seems like there are some really knowledgeable folks on here, so here goes...
I recently bought a 2005 Liberty with 3.7L engine. First DTC was cylinder 4 misfire and engine ran really rough. The dealer replaced a coil pack and that took care of that issue. Several days later (but not many miles) had P0430, which is a bank 2 sensor 2 efficiency code. Tried a product called Cataclean, erased the code. Light stayed off for a few drive cycles, then came back on. Went and bought a new Denso downstream sensor, but before I installed it the light went off. Figure I had the sensor so I installed it. Immediately DTC P0058 came up, which I understand MAY indicated I did not connect the plug properly. Had bad lighting and could not see it very well. I did hear a "click" so thought I had it plugged in properly, I'll check that tonight. Hopefully that will resolve that problem.
BUT, when I checked the DTC this AM (rainy wet morning) I saw a code for cylinder 3 misfire. Now I'm wondering if this engine is known to have problems with misfires/coils?
Any thoughts out there on what might be going on? Thanks very much!
