Jersey Jeep
I need some help with a YJ shifting problem. I have a 1989 Wrangler 4.2L / AX15 with 80K miles. In the last 15K miles I replaced the clutch and hydraulic throwout bearing assembly, I also installed the Mopar EFI kit (the stock carb is impossible), Borla stainless headers, new carpets/seats/top and wheels & tires. I am suddenly experiencing very hard shifting into first when stopped. Here are the symptoms: Trans cold, no problems. Trans warmed up, at a stoplight, clutch in, shift into neutral, let clutch out, light changes, press clutch in, cannot shift back into first unless I force shifter REAL hard. Sometimes shifting first into 2nd, 3rd etc, helps but its hard to get into those gears also. If the engine is off it shifts like butter. The clutch is definitely not dragging and engages smoothly. There is no hydraulic throwout bearing fluid loss. I changed and checked the trans fluid level (no metal chips on the drain plug). Normal shifting, both up and down is fine with no grinding either way. It doesn’t feel like the syncros as it shifts smoothly when driving (I could be wrong). It isn’t the ball detents on the shift fork shafts as it shifts fine with the motor off. It “feels†like when the oil thins out, something is spinning that won’t allow engagement into first. Any ideas on what the problem is? Should I try a new shifter first or just rebuild the trans? Any insight will be greatly appreciated.
Steve
Steve
