beepbloopjoop
I killed it as I was pulling the incline into the garage, and it wouldn't restart.
Nothing worked but the Parking lights which are factory in the front and LED in the back. If I switched on the headlights they all went off.
No blown fuses under the hood, or in the passenger compartment, however, three of the fuse connections are reading 12v on both sides of the terminals with the fuses pulled. Those are the "acc lps", "ign lps" and the big metal fuse-like thing on bottom center that is claimed to be for windshield wipers.
I tested each side of each fuse holder, and these three were the only ones that showed 12v on both sides, so I thought that can't be good.
If I connect my cheapo multimeter positive on a rust hole in the floor, and negative to the battery, it shows ~12v, so I think that means I have a short to ground. I assumed this meant it was in some circuit that was shared by all three of those fuses, but I'm not sure that makes any sense and nothing's turning up.
I have tried leaving the multimeter hooked to the body in this way, and jiggling bundles of wire here and there, pulling others, and disconnecting every connector that I can, just to look for a change, and nothing's changing. I unhooked the lighting switch and dimmer, the dash, and the stereo, but none of that helped, either.
I feel like I'm close, but maybe I'm completely misunderstanding. Anyone have any ideas?
