ok i think i found a good 4 inch lift for my jeep from sky jacker bear in mind im not really sure what a good lift is im going off the advice you all gave me. the product number is TJ403K-SX and the specs are
Description
Single Flex; Suspension Lift Kit; 4 in. Lift; Incl. Fr/Rr Coil Springs; Upper/Lower Links; Pitman Arm; Bump Stops; Sway Bar Links; Adj. Track Bar; Steering Stab.;
Contents
Part # Description Amount
TJ40F 4"FRONT COILS,97-02 JEEP TJ 1 PR
TJ40R 4"REAR CLS,HARD TOP,97-02TJ 1 PR
now i was wondering if i buy this 4" lift for my jeep is there any thing else that i need to make it work. are there any other parts that i would have to buy so that this kit would work properly. if there are any other parts what are they. and do you guys think that this is a good kit? thanx alot
mpm
Description
Contents
mpm
