1053367
Vibration and noise in the drivetrain are always a problem.  The sound and/or the vibration travels through the drivetrain and it´s hard to pin down.  I make periodic inspections in all my U-joints and front end parts.  With a flashlight, wiggle anything that wiggles, turn anything that turns, looking for play that shouldn´t be there.  It´s always easier to fix in the driveway than on the road.
  Could be tire ballance, could be mud stuck on the inside of rims.  If the rims are clean, swapping the front tires for the rear, and checking for a change in the vibration, often tells a tale.  Besides the tires usually have to be rotated anyway.
  The Quadra-trac has a history, of the transfer chain loosening up, could be chain vibration.
  When all else fails, I usually put it on a lift and run it in low gear (with a little brake applied) being real careful of the moving parts, and listen and feel, probable trouble spots.
edited by: MudderChuck, Feb 02, 2003 - 10:08 PM[addsig]
