Clutch or Transmission vibration
BaconYJ
Last month did Carnage in Boulder and had a great time creaping along doing all the same lines all the "hard core" guys did with a for the most part unbuild Jeep. About 200' after leaving the trail the rear driveshaft pops and bangs around under vehical while still attatched to the TC. Fix it and get moving again I shift to second and the whole transmission vibrates/shimmies then shift to third and its fine. The clutch was questionable in needing to be replaced 2 years ago when I had everything apart. I am afraid that either the syncro or a bearing is going bad. Was hoping the drivetrain would last a year or so longer before it was all upgraded. Any insight would be great.
Transmission = AX5
TC = NP231
4banger motor
1989 Wrangler
Thanks,
Matt
