cold inside & out
n2jeeps
Carb Rebuild Any Advice!
just bought a second jeep :P one for my wife. the easyest way to keep her out of mine :wink: . Its a 93' YJ great shape except the blower motor for the heater doesnt work. checked the plug and the fuse......any ideas?
pushes hot air only while moving.
Get a test light and see if you are getting voltage at the blower motor or not. If you are not getting voltage at the blower motor, then it is the switch, wiring, fuse, etc. If you get voltage at the blower motor and the motor is not turning, then it is the blower motor. Find out if you are getting voltage at the blower motor and post and we can help from there.
thanks DH30. power at the fuse box, no power at the motor. tracked down the wires to the switch and wire had came loose problem solved. thanks agian.
Be a Shark and never stop moven. hehehehe Good Luck in the repairs. Might be a good time for the Blazer heater motor upgrade. tug
tug, have done the "blazer upgrade" yet? I'm really thinkin' about it for my CJ. should have done it when I replaced the heater core.
