Hello!
1999 TJ 4.0 manual. At 2am today I was driving home, stopped at a light, and when I pressed the gas to move the engine stalled and would not restart. It cranks hard, battery is fine, but wouldn't start.
Today I checked my fuses and it looks like #18 under the hood, labeled as "fuel injector", was blown. I replaced it, tried to start the Jeep, the fuse blew again. Discovered that fuse #27, leak detection pump and O2 sensor, was also blown. Replaced both and the engine fired right up.
I checked the fuel injector wiring and I don't see anything exposed or rubbing.
Short of going over the entire harness what would be the next place I should check?
