f/s locked dana 30/ front control arms / other stuff
tow_hook
the old xj is now done, i have some parts for sale time to make a new one
for sale: pics avl
tera flex gen 1 control arms uppers and lowers: fits any tj/xj/zj/mj the lower arms need front bushings. 250$ for the set of 4
rubicon express xj drop brackets with braces: repainted with hardware. 250$
dana 30 hp : fits any tj/xj/zj/mj 4:10 gears/ aussie locker ( 4k on it) / big joint shafts/ 1 new spicer 760 joint/ 2 new pass side ball joints/ new inner axle seals /new pinion seal/ currie bottom control arm mounts/ skids / 2 calipers less the 1 year old/ 2 inch bump stops. no hubs/ unit bearings 550$
2 rancho 5000rs shocks part# rs5012 hole to hole style 32.5" open 19" closed 50$ lower bushings have play in them
93-9?" cruise control unit ( the pump and cable to throttle body from undwer the hood) 10$
xj "steel tank" fuel pump $10
u-haul trailer wiring kit fits all models $10
ipf rear back up light, used, with all wires, turn on switch button missing. 50$
http://www.quadratec.com/products/97017_1200.htm
denman ground hog tire: 40-17-15 brand new, never on the road. used as a coffee table no cracks, no dry rot. asking 200$
early cj-5 rims 15 x 7 : rims are white, 5 on 5.5" bolt pattern and do not fit over a disk brake system. for use with drums only 100$ for the set of 4
shipping from zip code 15905, thanks for looking
