So i was thinking about installing a daystar 1" body lift in my TJ. Now the thing is the transfer case linkage must be adjusted right? does daystar's kit come with that? also the fan shroud..but that'll be easy. My main issue is I do plan on installing on board air shortly after my body lift...will my fender thing get in the way of the compressor after the lift is installed? Also will i have to adjust the AC lines with the body lift? Other options is motor mount lift? Then if i end up doing that my transfer case will kinda hang down on a funky angle. how does this get fixed?
