Jeep Parts For Sale
MORGSTER
Jeep parts For Sale.
Way too many pictures for the site.
See photos at Support Groups for Jeepaholics - Jeep TJ YJ Rubicon parts 7/18 update
Thanks,
Mike
For Sale Wrangler TJ brake booster.This was removed from a 1999 TJ
and it is in no damage, ready to install condition. It is sold as shown, booster and mounting nuts.
Sell $20.00
For Sale TJ rear door hinges. These were removed from a 2004 TJ Jeep Wrangler Rubicon and are in used, but no damage (except bouncing around the garage paint chips) or wear, California Jeep no corrosion, ready to install condition. They are Sienna Pearl Coat in color. They open and close just like stock, no play.
Sale $50.00 pair Shipping $10.00 USPS CONUS
For Sale TJ factory exhaust heat deflector This was removed from a 1999 TJ. It is in excellent, no damage, ready to install condition.
Note: This heat deflector is not bent, deformed, damaged. This is how they look, fit to the TJ tub. Thanks to everyone who asked me why im selling a bent part.LOL
Sell $35.00
For Sale Wrangler TJ air bag module.This was removed in perfect working order from my 1999 TJ and it is in no damage, ready to install condition. It is sold as shown.
Sell $25.00
For Sale Wrangler TJ steering wheel air bag This was removed from a 1999 TJ and it is in no damage, ready to install condition. It includes the airbag,two mounting brackets and four mounting nuts
Note: If shipping is necessary, it must go ground
Sell $135.00
For Sale TJ Front valance This was removed from a 2004 TJ Jeep Wrangler Rubicon. It is in excellent bolt on ready to use condition. The color is Sienna Pearl Coat.
Sell $95.00
For Sale Jeep Wrangler TJ Wiper motor assembly. This was removed from a 2004 Rubicon. It is excellent, no damage, ready to plug in and use condition
Sell $75.00
For Sale Wrangler Steering column from a 1999 TJ Sold as shown, excellent condition, worked perfectly when removed, no damage, ready to bolt in. Includes adjustable column with wiper switch, turn signal switch, flasher, key switch and includes key. (This has the factory non coumpter coded style key switch)
Sell $125.00
For Sale Hayden 12" electric "pusher" fan
12" diameter x 2 3/4" tall. This was mounted in front of a YJ radiator for a secondary trail cooling fan. It is in excellent looking and operating condition
Sold as shown.$20.00
For Sale TJ t-case floor shifter assembly. This was removed from a 1997 TJ and is in excellent, no damage, ready to install condition.
Sold as shown
Sell $25.00
For Sale YJ rear sway bar axle mount for a lifted Jeep. This was removed from a 1989 YJ that no longer needed a rear sway bar.
Sold as shown.
Sell $10.00
For Sale Jeep Wrangler TJ clutch assembly.
This was removed from a 1999 TJ 4cyl 5speed, still has the fluid inside and is ready to bolt on and go. It worked perfectly when removed and is no longer needed.
Sell $50.00
For Sale Jeep Wrangler TJ dash panel speaker grills.This includes the right and left grill. Color light grey.
Sell $30.00 pair
For Sale Steering colum "lower cover".Color Agate/dark grey.
Sell $15.00
For Sale Steering colum "upper cover".Color Agate/dark grey.
Sell $15.00
For Sale One TJ Rubicon steering wheel "rear cover". Color Agate/dark grey.
Sell 20.00
For Sale one Fan clutch with Fan and mount. This was removed from a 1989 YJ 4.2 during the electric fan upgrade. The clutch bad been recently replaced during normal service. It operated without any cooling problems, just wanted to try the electric setup. Sold as shown
Sell $45.00
For Sale one YJ Dana 30 passenger side outer shaft. It is in excellent condition. Great for a trail spare.
Sell $15.00
For Sale two billet license plate frames.
Sell $8.00 each
For Sale TJ front fender liners.These were removed from a 2004 Rubicon. Excellent condition, no damage condition
Sell $20.00 pair
For Sale YJ Floor Heater box deflector.This works great to send the heat to both foot wells. This is a direct fit part
Sell $10.00
For Sale Jeep Wrangler TJ metal dash backing plate. This was removed from a 1999 TJ. It is in excellent, no damage, no rust, ready to install shape.
Sell $25.00
For Sale Driver side TJ roll up factory window/glass. This was removed from a 2004 Rubicon, factory tinted and it is in excellent ready to install condition. Includes two through glass bushings
Sell $45.00
For Sale Passenger side TJ roll up factory window/ glass. This was removed from a 2004 Rubicon, factory tinted and it is in excellent ready to install condition. Includes two through glass bushings
Sell $45.00
For Sale Wrangler TJ driver side window regulator.This was removed from a 2004 Rubicon and it is in excellent, no damage, ready to install condition.
Sell $55.00
For Sale Wrangler TJ passenger side window regulator. This was removed from a 2004 Rubicon and it is in excellent, no damage, ready to install condition.
Sell $55.00
For Sale TJ Rubicon stock rear bumper.This was removed from a 2004 Rubicon and is in like new condition. It includes the bumper only, no end pods.
Sell $15.00
For Sale Factory Wrangler 4cyl air filter box. Removed from a 1999 Wrangler TJ. It is in no damage ready to use condition. This includes both top and bottom, screws, clips (no air filter, well you can have the old one if you want)
Sell $35.00
For Sale Dana 30 stock Spider gears. These were removed from a 1989 YJ front Dana 30 3:07 front end. They are in good shape. If you need these, here they are. They were marked for location when removed. Note: Marks were made with paint pen and wipe off easily
Sell $20.00
jeepin916
Thanks for the heads up.
The site had some system issues and they are in the process of correcting them.
Pics should be back soon. (Cross your fingers) LOL
Thanks again,
Mike
clutch
I was wondering if you still had the clutch assembly?
