Try this:
Wiring Diagram
Circuit and Wiring Diagram for Automotive, Car, Motorcycle, Truck, Audio, Radio, Electronic Devices, Home and House Appliances
Search Results for "jeep+cj+ignition+switch+schematic"
Sponsored Links
Jeep CJ-5 Wiring Diagram
Thursday, 24. February 2011 by wire
The following schematic illustrates the
Jeep CJ-5 Wiring Diagram(with F-head four cylinder engine).
1. Left headlight
2. Left parking light
3. Right parking light
4. Right headlight
5. Negative ground cable
6. Generator
7. Distributor
8. Battery
9. Positive cable
10. Ignition coil
11. Coolant temperature sending unit
12. Starter motor
13. Voltage regulator
14. Starter switch
15. Fuse
16. Instrument cluster
17. Ignition switch
18. Horn button
19. Directional signal switch
20. Right tail and stop light
21. Left tail and stop light
22. Fuel gauge sending unit
23. Light switch
24. Stop light switch
25. Dimmer switch
26. Oil pressure sending unit
27. Horn
28. Junction block
Category:
Automotive,
Jeep,
Jeep CJ-5 Comments (0)
Jeep CJ2A Electrical Wiring Diagram
Friday, 29. January 2010 by wire
The following schematic shows the Jeep CJ2A Electrical
Wiring Diagram and Cable Harness Layout.
1 – Left headlight
2 – Left parking light
3 – Right parking light
4 – Right headlight
5 – Generator
6 – Distributor
7 – Voltage regulator
8 – Negative ground cable
9 – Battery
10 – Positive cable
11 – Starting motor
12 – Starting switch
13 – Horn
14 – Ignition coil
15 – Ignition switch
16 – Ammeter
17 – Dash light
18 – Tell-tale light
19 – Fuel gauge
20 – Light switch
21 – Fuel gauge sending unit
22 – Tail and stop light
23 – Light switch circuit breaker
24 – Dimmer switch
25 – Stop light switch
26 – Junction block
