1043715
I have a 95YJ when I turn the key to start it the engine turns over fine but will not start, the check engine light will not come on either. If I turn the key to on and let it sit a while (3-20 mins depending on how cold it is) eventually I hear a clicking from the power distribution block the check engine light lights up then the fuel rail charges and when the clicking stops the engine will start and run fine. Once the engine has been started if I attempt to start again right away it starts fine. Any idea what this problem is?
