Wheel Fit ?
blazntn
I have had a guy wanting to trde me for some cherokee ofr grand cherokee wheel with some 33's on them. will they fit on a YJ or is it a different bolt pattern, or is the offset going to be enough?
The bolt pattern should be the same. I'm not much help on the offset, but I'm sure you'll get the right answer here. I'm assuming you've got some lift on that YJ, or you can forget the 33's.
That depends on the year Grand Cherokee. The newer WJ (98-2004) wheels will not fit on a YJ, they have a different bolt pattern. The older ZJ wheels will fit, they use the 5 on 4.5 bolt pattern.
Well, shut my mouth!! I've learned something new (again....always on Jeepz). Thanx for straightening me out Twisted. Something I have filed for future reference..........I knew he could get the right answers here!
