RE: Question to moderators
Ok. Going to pull off intake ect to gain access to freeze plugs(leaking). Paying attention to what goes where ect. and I have a couple questions.
1) What is the silver cannister behind the carb has a green label on it?
2) I see a silver box about 4" X 4" on the driver side fender has the letters EF then like 12 numbers..tell me this not a computer. I want a 'puter free engine?
3) what exactly do I need to remove to have All smog stuff removed. I have the smog pump off isee a metal tube running the length of the valve cover on driver side with little tubes going to block?
4) LAst one for now
if I plug the vacuum tree on the lower side of the drivers side block, will that handle capping off most of the vacuum lines running to smog crap?
I am new to the 80 CJ. I can do it all myself but do need a little guidance as to what is what.
-D-
4) LAst one for now
-D-
