DavidRGallagher
85 CJ7
Nutter Bypass http://www.off-road.com/jeep/jnutter1.htm
TFI Upgrade http://www.jeepz.com/modules.php?op...file=engine_tfi
Weber Carb
New 258
Problems:
Hard to start in morning. Turns over and dies right away. If I hit gas after it turns over it dies
Backfire / breakup from carb under heavy acceleration
Losing manifold vacuum under heavy acceleration
Checked the following
Cold start issues:
Choke is set right
Backfire issues:
Thought it was a timing issue - Timing OK - set to 10 BTC
All hoses look OK
Vacuum advance is holding vacuum
Checked ignition module - OK
Did not check compression yet.
Vacuum is 20 inch Gs @ idle
Installed vac pump onto vac advanced – pumped to 15 of vac – backfire problem went away and it was fairly smooth up to 3500Rs
At idle manifold vac @ 20 in - @ throttle response, vac drops to 0 and ported vac went to 5 inches of vac
Before vac applied, motor has major hesitation with, vac applied hesitation goes away – still breaks up slightly @ top end.
Other info:
Ran fine with all mods (NBP, TFI, Weber) and old motor.
Swapped motors and have not been able to figure out the problem.
What could be causing the problem??
Thanks,
-David
Weber Carb
New 258
Problems:
Cold start issues:
Choke is set right
Backfire issues:
All hoses look OK
Other info:
Thanks,
-David
