Few problems after the trip to Vegas, need some help
laneiac
So the YJ did great, ran real good except for the wind pushing against us and the high air making us lose power. Now that we are back, when I take off from the line in 1st the jeep shudders and the dash and shifter violently shake around. Doesnt look like anything is loose, but thought maybe it could be a loose motor/transmission mount, not sure though, hoping its not clutch. Second, when I kick the back right wheel, it makes a squeaky metallic sound which seems to be coming from the hub assembly, but its definetly coming from the back of the wheel. Any ideas before I rip it apart? Thanks, Lane
Ok, nevermind. There is fluid leaking out of my left side front axle. Guess I have a seal and perhaps a bearing shot. What should I do>
you can replace the seal... i believe there is just an inner seal at the differential... you have to pull the axle and diff carrier to get to it
